Ok so I am doing my inner and outer tie rods and have them done. I had to take the relay rod out to remove the old inners. Here is my problem. The studs on the ends of the relay rod just spin when I try to tighten up the nuts. I tried putting a jack under the bottom (where the grease zerk is) to increase the pressure on it so it wouldnt spin but still dowes it. the engine is out of the car so I have access to pretty much all angles. Please help! Do i need a new relay arm?
-Andrew
-Andrew
