Apr 28, 2012 #1 C CGASTON Well-Known Member Joined Oct 11, 2009 Messages 1,881 Are air bags still being used and if so, are they still the big red ones? Or is there a better alternative? Brand? And on the air bags what the pressure for left and right side? Sent from my iPhone using Turbo Buick
Apr 28, 2012 #2 huntsg Active Member Joined Aug 10, 2009 Messages 803 I still use the big red ones. Inflated to 20 lbs if I recall. Its an easy set up and you can put the valve in the trunk.
Apr 28, 2012 #3 C CGASTON Well-Known Member Joined Oct 11, 2009 Messages 1,881 20lbs for both sides? Sounds like a lot Sent from my iPhone using Turbo Buick
Apr 28, 2012 #4 huntsg Active Member Joined Aug 10, 2009 Messages 803 I'm only using the one on the passenger side. I could be wrong on the 20lbs. Its been awhile since I installed. I'll check it tomorrow.
May 8, 2012 #5 huntsg Active Member Joined Aug 10, 2009 Messages 803 Sorry it took me so long. It is 12 lbs.
May 8, 2012 #6 S SHADOWII Well-Known Member Joined May 12, 2004 Messages 2,608 I have both @ 5 & 10#s.
