anyone every use this
http://www.jegs.com/p/Ridetech/Ride...-Carlo-Air-Suspension-System/1199214/10002/-1
To be honest with you I never heard them run and I have been around a bunch of air ride equipped cars at these Pro-touring events...How is the noise of the compessor? I can make room in the trunk, but not sure how often it is on, etc.
A friend of mine has a Cadillac with air ride and it is dead silent.
Yes it is completely "Bolt In"....Is Level 1 completely bolt in? Anything else needed or can you just roll with that?
RideTech was with us at this years Buick GS Nationals in Bowling Green, KY for three days pretty much doing the same thing, Great group of guy's....So Cal has Ride Tech coming out Dec 28th to demo and Q&A session here is Phoenix. Going to get the low down...
Okay... here is the deal without the level pro say you have your normal settings at say 80 front & 60 rear and today your loading 3 more of your buddies in the car to go somewhere, (Without) the level pro your rear setting of 60 will no longer support the added weight so you have to manually touch the button inside the car to add air and adjust for that extra weight, then when that extra weight is out of the car it would have to be manually set back by letting air out... With the Level Pro system that is all done automatically for you as it senses that for you and does ALL of the adjustments for you... Worry free / Hands free.So do you think if I am going to go air ride, I should have these?
Seems like they would replace sway bar? A little confused on all the options.
