Air to Water Inter cooler
J-B Racing
Forced Induction
Is anyone using one of these? I am informing myself into getting a PT2000 from PTE.
Is it worth it over the RJC IC 475!!!
Any info would be great.
J
Have you gathered any data on your current set-up such as pre intercooler pressure and temp ? There was a good thread on intercoolers in the general section that got some good traffic.
With that being said, I would wonder if any performance advantage would offset the weight. Are you going to eliminate the radiator and cool from a common tank ?
AG.
AG.
The readings is not the issue. I am planning on blocking off the Grill and do not want any heating problems, so I am looking into a Liquid Cooler if that would,be better. Unless I do testing first before converting. I see that Liquid is adding a lot extra weight that at the end is it worth it!!
I got an insane deal on a used PT3000. Now to figure where I am going to put it without losing the passenger seat!!!
