alchy install: wiring (which spade connector to which terminal on bottle?)
GN SBS
Hi folks,
A quick alchy install question (can't get in touch with SMC)--
When connecting the wiring harness to the bottle, there are two spade connections to what looks like a switch, but the instructions do not indicate which wire to connect to which spade-- what is correct?
Note that I'm not talking about the 2 male/female connectors-- I'm not quite slow enough to miss these...
thanks,
Scott
Not sure if I'm following your question correctly, but the terminal with the 2 black and 1 green wire goes to the pressure switch, and the 1 black and 1 white terminal goes to the low alky sender.
I'm talking about the wires to the pressure switch (2black, 1 green)-- there are two spades on the switch and I'm wondering which gets the black and which gets the green wire.
thanks,
Scott
It doesn't matter. Either one to either one will work. It is just making a circuit.
I had the same dilemma so I calld Steve at SMC. He said either one to either one.
Thanks, that's what I thought and how I hooked it up last night, but nice to know I won't have to change anything.
