hi i have a stock 84 t type.
if i put a alky kit on are there any chances of blowing the engine .i do not plan to going to the track an raceing.
i just want it a driver.
thanks harold
No you would not blow it up by just adding alky. It would help with your octane level if you turn up the boost. Probably would not make a big difference in a stock configuration without turning up boost.
get alky. its one of the best mods you can do. you will be able to run more boost on pump gas and it would cool the intake charge thus creating more power. you wont hurt the car at all you will only help it.
Yep, call Julio and order a kit for a hot air car, they are a little different than the ic kit. My kit was a little over $600 which I just bought this spring.
