Alcohol AFR
spins4
Those of you with full-time widebands what kind of AFR do you shoot for when spraying a good amount of alcohol and say 25psi boost on pumpgas?
I have heard it is better to run it rich, but that is on a pure meth fuel system.
Just wondering what kind of results you guys have been having.
Also, has anyone tried running 2.0BAR boost on Ethanol (Denatured Alky), or is that a Methanol only type activity. ;)
Whether running alcohol or not it should not effect the A/F ratio goal.
Bruce and others usually recommend around 11.2 - 11.5:1
