alcohol fuel pumps
redhotrod
Turbo Happy
What are you guys using for an alcohol fuel pump in your hotair? It isn't the same shurflow the intercoolers are using is it?
This is the one right?
Item# 26871
SHURflo 12 Volt 2.8 GPM On-Demand Diaphragm Pump, Model#
1202.1000
For boats, RVs and more!
In Stock
Ship Wt. 5.0 lbs
Item# 26871
Discount Price... $74.99
110% Guaranteed Lowest Price! Qty
Additional Specifications
Lifts water 12', runs dry without damage!
Check valve prevents backflow up to 200 PSI
Low RPM, permanent magnet motor
12V DC, 40 PSI, 4.0 Amps; IAPMO and CSA recognized
http://www.northerntool.com/webapp/...&PHOTOS=on&TEST=Y&productId=7273&categoryId=0
Thats the page I found it on, I see its only rated for 40 psi though, isn't that low for a car running 20 psi boost or more?
THIS ONE :
Shurflo item #2687 (model #8000-543-236) : $59.99
Comes set at 60psi, capable of 200??psi.
Post/search in the alky forum for info also. If you really want to get off on the right foot with alky injection, talk to Razor. He has the best stuff going right now, and his advice and knowledge is second to none, he has done his homework ;) .
