Alcohol=traction
slamming 6
Drag Master
I have dialed my alcohol to spray a little sooner and noticed that the car is leaving a bit harder when runing on the street due to the slight bog. Not enough to notice on the tach or hear but enough to allow the tires to bite, has anyone tried this before this would not work at the track i dont think because of the sticker surface.
If you spray a lot too down low, it will bog and not let the turbo spool as fast cuasing the motor to not come up on RPM's as fast. I noticed this when I made my very first progressive controller using the 2 bar sensor back in april this year.. Same thing happens if you start to build boost and you start spraying. Hence why I went to the 3 bar and a limit input on the controller.
Track times will go down by 3-5 tenths using this flood approach, yet the benefit on the street is that it lessens the tires from blowing away from boost rising very fast.
I have brain lag,Iget what you mean your DIY alcohol Injection site was my source when I needed part# and some wireing info thanks steve.
