ALKY and reformulated fuels
dodgeball
I'm considering going with an alky kit. A friend of mine said with the reformulated fuels we use here in milwaukee I wont see that much more boost. I believe its the same mixture here as it is in chicago a 10% ethanol blend. Anybody out there have any experiance with alky and these fuels. Thanks!
Alky will allow you to run more boost even if you use 87 octane fuel. You have to go to basics as to the reason alcohol injection works. You do this, you will see.
Now if you can run 30 PSI on reformulated fuels.. ahh.. that one cannot answer.
