 , so I upped the ante a bit.  After doing a lot of research, it looked like alky would fit the bill very nicely for my goals.  So, I got the PT51, 50# injectors, and the alky kit.  I should be able to safely turn up the boost and timing without having to hunt around for race fuel or destroying my O2 sensor and my cat.
, so I upped the ante a bit.  After doing a lot of research, it looked like alky would fit the bill very nicely for my goals.  So, I got the PT51, 50# injectors, and the alky kit.  I should be able to safely turn up the boost and timing without having to hunt around for race fuel or destroying my O2 sensor and my cat.Originally posted by turbojimmy
You hear people ask this over and over again, but it applies here, too:
What are your goals?
I ordered my SMC alky kit because my (current) goal is a high-11/low-12 second *street* car. When I do go to the track, it's on test-n-tune days. I like to know what the car runs, but I'm not really interested in "racing" it. The Friday night street legal drags are fun, and an 11 second car would be close to the top of the heap. I don't want to have to run race fuel all the time because I drive the car a lot - to work and back, to get groceries, or just for the heck of it. Until last weekend, it had the original O2 sensor in it and I still have a cat because I have to have it inspected every 2 years.
Even though my sig indicates a mid-12 second car, the reality was that was accomplished with a 104 octane chip and 108 octane leaded fuel. My car isn't a mid-12 second car. It's really a mid-13 second car in "street" trim (94 octane fuel; modest timing; less than 20 psi boost). There are a plethora of other cars that would (and do) give me a run for my money on the street. My dad and my brother own two of them (LS1 powered F-bodies). That makes me uncomfortable, so I upped the ante a bit. After doing a lot of research, it looked like alky would fit the bill very nicely for my goals. So, I got the PT51, 50# injectors, and the alky kit. I should be able to safely turn up the boost and timing without having to hunt around for race fuel or destroying my O2 sensor and my cat.
I haven't read anything that would lead me to believe that alky is a substitution for common-sense tuning. My impression is that it's only a substitute for the lower-octane race fuels. The same amount of tuning is necessary, maybe more to get the spray right on the alky, whether you're using alky or race fuel.
If going *real* fast becomes a goal, a whole lot of other things would have to happen, and the alky may not make sense at that point.
Just my .02....
Jim
Originally posted by Look Quick
Matt--I see you live in Burlington. I will be moving to Mebane next Spring. We will have to get together.
Matt--Any drag strips within an hour of Burlington (1/4 or 1/8)?
