With everything being equal, that engine should run like a top on Erics default settings. You removed 6 degrees of high gear timing if you moved it to 110. I ran CR43TS plugs from my friendly GM dealer. Again, I'm not an E85 guy, so ask for a correct plug. Kindly answer Chucks plug question. You said you're seeing KR slowly leaning into it. I'm taking a wild guess that 340 pump ain't cutting it. Disconnecting the orange wire by the battery will reset Erics chip to default. Put correct plugs in it from a gent on here that's well versed in E85. When you do that, I'd add the whole 20 percent of high gear fuel and slowly lean into it...but get out of it immediately if you see a hint of KR. If the KR comes on a tad later then it ain't getting enough fuel and it needs the bigger pump. I'd contact Eric for pump size, but I bet he's gonna tell you it needs something largerlol
			With everything being equal, that engine should run like a top on Erics default settings. You removed 6 degrees of high gear timing if you moved it to 110. I ran CR43TS plugs from my friendly GM dealer. Again, I'm not an E85 guy, so ask for a correct plug. Kindly answer Chucks plug question. You said you're seeing KR slowly leaning into it. I'm taking a wild guess that 340 pump ain't cutting it. Disconnecting the orange wire by the battery will reset Erics chip to default. Put correct plugs in it from a gent on here that's well versed in E85. When you do that, I'd add the whole 20 percent of high gear fuel and slowly lean into it...but get out of it immediately if you see a hint of KR. If the KR comes on a tad later then it ain't getting enough fuel and it needs the bigger pump. I'd contact Eric for pump size, but I bet he's gonna tell you it needs something larger.
thats the odd part everything was set on default and it ran amazing would pull very hard, I drove it for a couple days then out of no where it started pulling timing. I only replaced those plugs because that’s what was recommended to run with those heads. I guess I could call champion heads on Monday and see what the recommend running. As far as the fuel pump it’s not running out yet I installed a gauge and taped it to my windshield to today, set base do at 45 and went and ran it easy pressure never fell and would rise with whatever boost I put on it.
