P
PowerV6
Guest
OK i know my combo is not up to this right now so heres it goes and tell me if it even has a chance to run high boost....i just purchased a pte-53, basically got it for a decent price and i could not find what i wanted used...so i had to get it, even though it was too much for my combo, anyways, i have a stock intercooler, 36lb injectors, 2800 stall convertor...i know its not enough but i can handle a slow spool worried more about fuel, Smc alcohol kit...single nozel...could this offset the injector size some...enough for me to run higher boost, hotwired fpump, 307 walbro fpump, i do not knock @ 20lbs of boost on a 100 jay carter chip and stock turbo....also i will be installing an external turbonetics wastgate and 3 inch dpipe...tell me what you guys think and what i could expect from this combo! THX BEFOREHAND, ill tell you the results and if it is a problem after it is installed...
