Alky control 3 bar map alky test kit help.
434nova
First what is the alky pressure suppost to be when you hit the test button. I am only getting about 40 psi. Also what is the psi at full boost 150 psi ?
Second how do you hook up the 3 bar test kit with a fast xfi. I cant plug it into the 3 bar harness it won't fit.
I then went and plug it into the to the tps harness direct it fit the plug and it still wasn't doing anything on the gauge and the pump won't turn on. I had the knob all the way to 30 psi and pump didn't do anything.
How does the 3 bar map alky test kit work?
