bobs84ttype
- Nov 24, 2006
more specific the lighting. i have aftermarket inst. cluster After reading the instructions i understand the low level led. and that will be fine
1st question. is the power injection bulb just a on off light or does it only come on when alky is spraying?
I wont be using the actual bulb and was wondering the function so i may make a choice as to what to replace it with.
2nd question
instructions make reference to a red/green led the should change from red to green after pushing the test button. ( which does not seem to be included with the kit.) again i wish t0 know the function of this light so i may look into other choices
does the red/green led change based on voltage?
I dont have much luck with red/green led lights due to vision issues. that is why i would like to look in to other lighting options for the proper operation of the system
Thanks Rob
2nd question
Thanks Rob
