Alky kit for sale
vacuum 6
I have a used BGC alky kit for sale. New this kit sold for ~$250. I added two keys parts to the kit and now it works even better…an NOS alky solenoid and one-way check value (both are methanol compatible).
http://www.mcmaster.com/nav/enter.as...21&pagenum=379
http://www.jegs.com/webapp/wcs/store...chItemId=39921
Kit comes with an overflow tank, lines, activation (pressure) switch variable turn on point 5-15 psi, pump, NOS nozzles (.014 thru .070), one-way check value, NOS alky solenoid w custom holder, and instructions…everything you need. I’ve run methanol + lube thru it for two years with zero problems. My car went 12.25 @ 111 with this kit (.035 NOS nozzle and a TT alky chip). This kit flows more than enough. Make offer!
Flow rate of this kit @ 25# of boost
Nozzle (flow-rate GPH): .035 NOS (14.43), .050 NOS (28.13), .060 NOS (35.80)
Flow rate @ 250 psi for the M series nozzles from Hago
Nozzle (flow-rate GPH): M2 (3.16), M5 (7.91), M10 (15.81), M15 (23.72)
__________________
__________________
TTT
