I made a quick trip back to the dyno last Saturday to retune the car after adding a second alky nozzle. After the runs I made back in October with the alkycontrol.com PAC kit with a single M15 nozzle, I found that the car made great power (500 whp), but it was a little bit too lean up top for my liking. There was no knock retard, but in the interests of long term life, I wanted to spray more alky. My gasoline delivery was also maxed out. Thus, the addition of the second alky nozzle, which was an M10.
Since Julio is local to me, he came to the dyno with a 0-300 psi pressure gauge, some braided hoses and the appropriate fittings to tap into my alky feed line so we could watch alky pressure under boost on the dyno.
Well, the second nozzle certainly did the trick! We were able to get A/Fs right down where I wanted them. With the single nozzle, I was creeping on 13.5:1 way up top, but with the second nozzle, we were able to get a nice flat 11.8-12:1 up top. The car was actually making a little better power for a given boost level than last time, but we couldnt get the car to make 34-35 psi boost on the dyno as I see on the street. I guess the load just is not there with an inertial type dyno on my small engine which needs all the load it can get.
The alky pressure ramps up in a HURRY with the settings I have on the PAC. (I need to have an aggressive reamp due to how this turbo spools. When it reaches its threshold point, it shoots boost up to peak almost instantaneously.) Under full boost, we saw a peak of 170 psi alky pressure even with the twin M15 and M10 nozzles spraying full tilt. And, the pressure needle didnt budge.
I calculated out the alky flow rate and its about 2225 cc/min. The 15 gph (M15) and 10 gph (M10) nozzles (a total of 25 gph when rated at 100 psi), end up flowing about 32.6 gph at the measured 170 psi pressure. Methanol is about 6.5 lb/gal, so thats 211.9 lb/hr, which equates to 2225 cc/min. Thats alot of spray! My base gasoline fueling works out to about 208 lb/hr, or 2184 cc/min.
I have a video of the pressure test, which is shown below. Please right click and save as----
http://mysite.verizon.net/res1elpe/alkypressure-large.wmv
When you do the right click and save as of the file, make sure to specify the file type as "all files". Youll then physically have to type .wmv after the file name. For some reason, when an attempt is made to save the file, it defaults to an .htm type. I have no idea why its doing that
