turbognx75
- May 19, 2010
Driving my car last night I noticed knock with the alky kit on, alky was all the way up,,,,,,when it gets to 15ish psi the red light comes on showing me that its spraying,,,so I hit the test button and does the same thing red light comes on.... Car been sitting for a while it got a new fuel pump, it's the older PAC alky kit from 03 #022 it worked fine up until last nite so I started checking things,,,,,,ign on I hit the test button and I hear like a buzzing sound coming from my speedo cluster, I checked the PAC box it wasn't making the buzzing I checked the other box with the positive/negative/ground wires and that wasn't buzzing neither so when I hit test button I hear buzzing in dash cluster and the pump does not come on, the pump just clicks when i hit the test button but when I disconnect the ground wire from the pump and ground it elsewhere pump comes on, I checked wires for the kit and they are all good not sure why its buzzing when I hit test button and not sure if when I was driving and hit 15psi if it was buzzing "car kinda loud" any help or advice would be great thanks
