alky kit
pajo
I have purchased a partial progressive alky kit and need some help locating the missing parts. The line from reservoir to pump(what size is it ), wires cut from the reservoir level sensor - where does it plug in , Any input is appreciated ..
Your best bet is to contact Julio since he makes this kit. His name on here is Razor. He will be able to get you up and running.
yup.. Call Julio.. Also may look at the date on the pump. They don't go forever.
Thanks - He was the first person I contacted and after couple of emails he is not responding so I fugure maybe somebody can help out from this board.
That pump is an early version. As mentioned, it may be ???
Suggest you call Julio, and send it back for rebuild..If possible.
I would basically box up the whole mess and send it to Razor. Ask him to complete the package and test everything and send it back.
Thanks on all inputs - The pump checks out ok or i should say it runs , once I get it all plugged in will find out if it puts out pressure and how much - I ordered the 3bar map, now I need to get the line from reservoir to pump it seems that is 1/2" but dont know how long .
