NY Twin Turbo
All the good stuff.....Times 2.
- Dec 10, 2014
It takes about 30 seconds to pull a point or 2 out of the VE map in those very few cells. Maybe even add a little timing to take advantage of the cooler intake air temps and higher octane too. Even distribution of alky can easily be seen on a data log. I have 6 EGT probes and except for idle, I have my corrections set-up to be all within 50 degrees of one another. Most times even much closer.if the car has no knock with a good afr and runs real good I would leave the curve alone.
As a group, I don't think we ever leave well enough alone. I know if I did, I wouldn't be where I am right now.
