Hello all;
For those not familiar with my setup I have a 1980 olds cutlass with a 1979 Buick turbo V6 (carbed not fuel injected) . Its far from stock , fully ported & poslished heads (cast) , forged TRW pistons , balanced , Comp 252 cam & lifters.
The turbo is not stock , It is hybird t3/t4 , with a stage III turbine wheel & "V" seires wheel on the compressor side . I run 22# on C16 and run low 13's (see sig.file). ( turbo is presently at turbonectics getting rebuilt becasue the seals , bearings and housing let go on it).
I have made a alky injection unit with a Ford F.I. pump , NOS nozzle and a .028 jet.
I have also made a a varable speed (PWM) speed control that turns on and vaires the pump speed with Boost presure use a 1 bar MAP sensor.
The question for the group is : Running 93 octane pump gas , is that jet big enough ? I have mearsured 100 psi at the nozzle so there is plenty of pressure , or is that jet to big ?
I am using isporpyl 70 % , Use I include a shot of oil with that ?
If the turbo gets back in time next saturday there is a dyno day I like to attend so I can dail this in . I also bracket race every weekend , So If i do't have to buy race gas , This will be a big savings.
The carb has 67 jets in the front , 74's in the rear , 8.5 Power valve . Total timing is 40 ° , But I am running a MSD6BTM that take 1 to 3 ° timing out for every pound of boost it see's , I have it set at 1 to 1 so at 15# of boost there is 25° of timing , plus I'm taking out and other 3° in high gear ( wired boost retard) that I can set to 0° or has high as 15° .
What is the opinon out there , that may save me some time on tuning this carbed beast
Thank's , Fred
Thank's , Fred
