Alky results
Otto J
My car usually on the datalogger showed a increase of 40-50 degrees over ambient at the end of a run
Sat it launched at 61* and stayed there thru out the entire pass,And it showed as soon i lifted the throttle that air temp climbed right to 98*(when the Meth shut off)
I will be doing more testing with more boost the Fri
Thanks Razor everything works great
My car also went almost as fast with 25#s and Methanol
as it did with 30#s without it
Otto,
Keep us informed, we are thinking about putting this on the twin turbo v-8 car.
Will do, It is starting to get colder here so results are going to be a bit off.
