Alky with stock combo
dice64
Anybody used this with stock motor,turbo,intercooler if so what are your results.How much boost can you obtain with the stock turbo with it before the stock turbo heats up the air.
I ran a Modern Musclecar 108 race chip, 21 lbs of boost and alky for well over a year with the stock turbo/intercooler/injectors etc. That was real fun on the street!!
Make sure you have all the supporting mods IE... Scanmaster, fuel pump w/hotwire, fuel pressure regulator etc.
There's no downside to alcohol injection.........modified or not. Protects your engine from detonation and helps keep it clean.
12.1 at 112 stock motor, stock IC, stock turbo with the simple mods, 160 stat, TB bypass, converter locked, Nitto's, valve springs, fuel pump, FPR regulator, RJC PP...and a mild timing chip.
22-23 PSI 1,2nd the 20 PSI through the traps.
HTH
Julio
MILD ;)
Actually I cant remember..i've had and made so many chips..I know I didnt run a 26 degree chip..I think it was a 21-23 degree chip.
DANG, BOB SAID YOU LIKE TO RUN LIKE 17 DEG ON ALKY CHIPS. IM AT 21 NOW. YOU KNOW WHAT KNOCK RECOVERY RATE BOB SETS IN HIS CHIPS? PAC ALKY IS SO CLOSE I CAN TASTE IT, CANT WAIT TO UPGRADE TO PROFESSIONAL GRADE, TRANSITIONAL KR BO SUS.
Alky is good for ALL TRs, haha ;) I'm pretty stock and if I can learn to launch I expect her to be well into the 12s.
The stock turbo is better at 22-23 psi than it is at higher pressures. It's getting out of it's efficiency envelope and will start blowing hot air at much higher pressures. My turbo is ported, so I keep her around 21.x psi with the alky. NO knock,even on the shifts typically.
For the money you can't beat it. It's not one of those "Well...I THINK I can feel the difference..." mods. More like one of those "scotch-guard the seats before test-driving" mods.
