alkycontrol install question
87-TURBO-T
I might have missed this in the instructions:confused: where is the best place to mount the main PAC module? thanks
All the ones we've had in the shop, theyve been mounted under the dash on the drivers side. For ease of access to adjust the settings, thats probably a good place for it. You could get clever and put it other places but then you'd have major work to do if you wanted to change any of the settings.
Hope these help. This is where I typically do it.
I put mine under the radio pod with enough slack in the wire so I could slide it out and adjust. Seems to work great. Totally hidden as well.
Jason
Mounted mine on the back of the heater box, easily accessible by opening the glovebox door. Also have my Powerlogger junction box in this location. Will try to take a pic for you later.
