Well I had the dual nozzle dialed in pretty good. Now I'm seeing knock. I tried hitting the test button while in boost and the knock goes away. All wires look good from what I can see. Don't see any bad connections.
If the car is idling it will just about kill the motor when I hit the test button. I know it's coming on just not supplying of enough voltage to the pump when making a pass. Vac lines to the map sensor look good too. All zip tied nice and tight. I'll call Julio this week, but has any of you guys had the same problem? Thanks
