Alkycontrol kit not spraying progressively?
TURBO 6
Beer Snob
Staff member
Well I had the dual nozzle dialed in pretty good. Now I'm seeing knock. I tried hitting the test button while in boost and the knock goes away. All wires look good from what I can see. Don't see any bad connections.
If the car is idling it will just about kill the motor when I hit the test button. I know it's coming on just not supplying of enough voltage to the pump when making a pass. Vac lines to the map sensor look good too. All zip tied nice and tight. I'll call Julio this week, but has any of you guys had the same problem? Thanks
Let me guess.. blew the hose of the MAP sensor :)
Could have been the poor conection that ties into the green map sensor wire. Fixed that.
I think alot of what I'm seeing is false I'm thinking. I mean I'm seeing knock under slow acceleration (turbo not even spooling). As much as 4* at times. Powerlogger resolution let's me see everything.
Julio I'll call you tomorrow.
You have to solder all critical connections. No exceptions.
I had a guy blow a head gasket becuase he wanted to use a scotchlock on the MAP connection. A 10 cent connector cuased 1k in damage.
I'll be in the shop until 6 today. TTYL
Julio
