Alkycontrol wiring. Help.
paulg
A chase is a race.
Okay my girl bought me my system used and it was a bit hacked up when removed. Finally got it all squared away (almost) just can't figure out where to hook up the Gray Auxiliary wire and the violet negative trigger. Would appreciate some help.
Pretty sure they go nowhere...I know for sure the violet one goes nowhere unless you have issues spooling the car up, but I don't know anyone that has used it always been able to tune the car to where it was not needed.
Okay good to know I just want to be sure. Tested the kit and the car stumbles so it's definitely spraying. Gonna call Julio and ask about the gray wire then give everything a once over and begin to tune. Tuning tips are welcomed! Thanks.
Leave the gray and violet wire un-hooked to anything.
Gray is an output wire for activating a solenoid driver, datalogger input, etc.
Violet is a reduction input. ground applied reduces output.
