JDSfastGN
- Jun 16, 2001
I just wanted to post a review of the dual Spal fan setup from Peter at Alradco. I was running a Lincoln Mark 8 fan using one of his aluminum radiators with pretty good luck (95* outside the with the AC it would run 195-200 max. The Lincoln fan was rated at 4500 cfm but did not cover the entire radiator. A few weeks ago the Lincoln fan crapped out so I decided to purchase his "extreme" set of Spal fans that are roughly rated at 2800 cfm. I was a bit apprehensive at going with fans rated at less cfm. I got the black powder coated shroud and man was it nice. It installed and fit as well as it looked. I wired the A and B together so that both fans would be triggered to come on when the low relay is engaged. I took it for a drive without using the AC initially and I couldn't get it to break 167-168 unless I did an extended WOT pull. but the fans would quickly pull it back down. The real test was with the AC on. I took side streets knowing I would hit a lot of lights and have to idle around quite a bit. It was still 92-93 outside and the car never saw above 178 I pulled into the driveway and let it idle with the AC blowing cold for a few minutes and the fans managed to bring it down to 174 before I shut it off. I could not be happier with how these turned out. They look and work fantastic. BTW I am running a pretty thick FMIC.
