Chris McDade
- Jul 13, 2001
Got the fans installed. This is a nice setup. There is a power wire coming off of the harness. Does this go to the battery or a power source that goes on/off with the key?
SignUp Now!I ran mine there because it was cleaner. Both in the engine bay overall and having one less wire coming off the battery. That just annoys me.I moved the relays and wires to the bottom of the fans so you can see them. I like the idea of running it to the alternator.
Backwards, clockwise or counter wise, which is itok, got the fans running but, they are rotating backwards??????????? Instead of pulling air they are pushing air out through the radiator towards the front of the car. Only thing I did to the wiring was extend the power wire so it would reach the altanator. There is a rotation tag on the fans and they are going the wrong direction.
Any idea's?
That same wire......with no installation instructions to go by is my excuse!
I will try to switch it over when I get home.
