Alston Chassisworks Varishock Double Adj.
Tiretoter
Chris Alston's Chassisworks Varishock (pair of front shocks)
Part # VAS 14245-425
Bolt in front shocks (pair), Smooth Body, Double Adjustable, 3/8" stem top mount, open crossbar lower mount, 16 adjustments for both bump and rebound provide 256 different settings. Very easy to tune. I have had these about a year. The car was run with these shocks on 4 separate occasions, and the shocks were removed during transport.
NOTE: Springs must be removed during shock installation. Shock body is too big to install from bottom of "stock" control arm. OR you can do like I did and modify your lower control arm so the shocks will slide in from below.
See other info attached.
Fit 68-79 Skylark and many others.
Go here for application chart for this shock: VariShock - A Chris Alston's Chassisworks, Inc. Brand
$578 per pair new.
Will take $400 shipped in Cont. US.
