Alternator Bracket
Mike E
Mr. Badwrench
I have a custom Alternator only bracket I had made when I was running no power steering or a/c. It is similar in style to the Champion Bracket. Everything you see is included. I was using it with a one wire alternator. A stock alternator will work, but you may need some metric hardware. This bracket hangs the alternator further off the head and will be just right if you are using an msd crank trigger behind your crank pulley, or if you are running a belt drive and everything is custom. I can shorten the bracket to work with stock pulleys if needed. This could also be easily reconfigured to run the alternator on the passenger side if you are doing something custom.
$150 shipped
