T
Turbo Dog
Guest
What's the best way to eliminate it? Thanks!
SignUp Now!Originally posted by Turbo Dog
I know Richard Clark would have a long list of tests to perform to track down the source of the whining, but I don't understand why you can't just swap radios and be done with it.
Those ground loop isolators do more just affect the bass sound, they affect the entire audio spectrum, subtle though it may be. If you are using good equipment you should NEVER need to use one of those. 99% of the time it is a ground loop or inductive noise (EMR). You need to have 1 reference to ground - and it should (will) always be the head unit. Every other component, including amplifiers, should have a very high impedance reading on the RCA's (pin and shield) to ground. EMR problems can ONLY be solved by re-routing the RCA cables away from the offending wires (or moving the offending wires). Sometimes even just moving the wires a little will eliminate this.I know its grounded good and its the car, so I pop in a ground loop isolator and this 75% correct the ground loop/noise issues. But "DO" not use inlie of the sub.
I always try to 100% isolate the low level signal wires. So, I'd put the power cable and speaker wires down the drivers side and RCA cables down the pass. side. The speaker wires will not inductively pick up any noise as long as they are run in a straight line. The only components that can inductively pick up noise are RCA cables AND inductors in crossovers. I don't think the speaker cables emit enough EMR to jump into the RCA's so your probably O.K. leaving them where they are at.The power wires are run along the drivers side, and all speaker wires are run along the passenger side.
I agree, but the cheaper ones do alter the sound a little. But don't tell that to the SQ SQ SQ guys over on Sounddomain.com. They believe they can hear the difference in SQ between 2 different brand high end head units. They would tell you it can be heard. I laugh when I see those posts.Ture but not a noticeable difference to the ear. I use higher quality ground loops so I don't run into those problems.
True, but when wire is wrapped in circles, ie a coil or inductor, it becomes much much much more sensitive to the noise. A straight piece of wire does pick up EMR but it is so slight it could never be heard by the human ear. But a crossover coil acts like an antenna and picks up even a small amount and transfers it.All wires can pick up inducted noise, any conductor in the presence of a EM field can get induced noise.
Ya, but were not talking about a grounded surface. True, the body of your car is one big ground. There is not one spot that is conducting a large amount of current. We are talking about wires that are carrying either a high positive current or a high negative current. GM is famous for using marginal sized wires. I know on my TTA under the pass side of the dash there is a bundle of wires that is just loaded with EMR. If I put a pair of RCA's within a foot of this bundle I get a ton of engine whine. Solution, keep the wires away form it, no noise.The whole idea of moving RCA's away from power cable's is really quite pointless...where does the ground in your car connect? The chassis. What are your cables laying on? The chassis....see where I'm getting at?
I worked at a shop in high school and first few years of college. My buddy owns the shop. He know in the area for doing high quaility work. He gets alot of re-installs from other shops for noise, hack work, etc. He still calls me every know and then when he can't find the sourec of the noise.Where do you work at? Yoy seem to be a very knowledgable/experienced person when it comes to Car Audio.
If you are using RCA plugs maybe. But from what I read you are using speaker leads all the way to the back and then a line converter in the trunk, so I'd say probably no. But, there is only one way to find out, move them.GN and TTA- Is this bundle also on the GN? Could this be the source of my problem?
Good. If grounding the radio better helped, try this - unplug the antenna connector in back of the radio and see if the noise goes away even more, hopefully all of it.I attached a wire to the back of the radio and grounded it to the metal frame where the radio bracket attaches to. It helped about 50 percent. Some whine is still there, but you can't hear it now with the radio on. Thanks for all the good advice.
