Ok, I've got an MTX 275w Thunder amp powering two 10 inch Cerwin Vega subs in my trunk. The amp is mounted on a small, carpeted pedestal, with not much room between top of carpet and bottom of amp. It sits next to the sub box on the upper area of the trunk (back).
It shuts down after about 30 minutes (due to heat, as it gets very hot to the touch), then cuts back in and out every 5 minutes as the temp goes back up and down.
Aside from removing the carpet on the amp pedestal, what else should I do? Is the amp too small? Is that the problem? The sound is fantastic, and have had no other problems.
Suggestions appreciated. Eddie, where you at, man?
