AMS 500 Question
DDot690
I am thinking about installing a AMS 500 Boost Controller I have. My question is looking at the instructions it doesn't really say how the two switches for input 1 and 2 work. I assume 1 could be push button for launch control. Can there be two switches mounted in the car to control two different boost levels, say a street level and a strip boost level?
And my last question is what are the metal fittings used to plumb the solenoids that use hard hose that push in and lock.
Input one {launch boost} cancels out input two {final boost}. For one use a sw. that will be released at laungh ...sw. on brake pedal or trans brake sw or roll control sw. for two use any sw you want dont forget to arm it before launch...micro sw. on the throttle activated when pedal is to the floor or plain jane toggle sw. If you dont use CO-2 as a reference pressure its not really accurate. Do it right and you will be happy with it
