an fittings for radiator and tranny
Ahh I see. it should be the inverted flare fittings like you had posted, depending on the radiator you are using.
Instead of reusing the brass fittings in the transmission, and adding on inverted flare adapter fittings, I replaced them with the fittings I posted. one less point to leak in the system.
thanks makes sence
how much line pressure will the 400 make? Want to get these fittings and run hose, but I'm not sure what hose to get.
