These are all hot idle after being driven and just installed the Powerplate..
AF 6
L8 43
INT 121-126
BLM 124 FINALLY YAY!!!
IAC 23
TPS .44
and I'm getting codes 22 and 44 argh!
Code 22 says tp sensor low but .42-.44 is right on at idle but at wide open it only goes to 4.00 max, what could it possibly be?
Also on the code 44 it says O2 sensor lean, could that hopefully be because I have a large turbo and stock fuel system? I don't give the car more than half throttle and the O2's stay around 800 usually so I don't see how it is running lean...
What do I need to do?
AF 6
L8 43
INT 121-126
IAC 23
TPS .44
