Tori
- Nov 4, 2013
How can i make this $%#@! alternator turn on ?
Just replaced the voltage regulator, and now no charge. Volt light does not come on with key, but i have the resistor bulb set up so that isn't a factor. Gauges fuse is good, I have grounded the brown wire at the alt. connector and the Volt light will turn on. I've removed the alternator and had it tested at O'Reilly. Watched the guy do it twice, passed both times, all 3 parts of the test. I have confidence in that. The alternator was working prior to replacing the VR, but voltage was constantly ranging from 13.8-14.5
Everything was working fine before this (aside from the VOLT light, it's never lit up like it was supposed to)
Down time was 1 day.
I've pulled the alt. back apart to check my work, and found nothing. Even compared it to a YouTube video to make sure it was done correctly, which it must be since it tests good off the car.
What can i do to make this turn on, i don't know where else to look.
