Hey guys, i need your advice here. i was out driving my car around today, never got any boost up, i cant realy because of my hooker headers and exhaust leaks, but i pulled up to my house in the front yard, to drop off some food. when i came back outside about 3 minutes later, i got in the car, and turned over the starter, and it clicked, wouldnt turn over. i turned the key off, turned it back on, and it cranked right up, but there was alot of smoke coming out of my tailpipes. white smoke, i think it was steam, but im not sure. i saw it, and turned the car off. I opened the hood fearing the head gasket had blown, checked the oil and coolant, both were right, and clean, no mix. so i cranked it back up to pull it in the driveway, and it smoked lightly out the tailpipes, and then after i got into the driveway, it quit. wouldnt smoke anymore. it still ran perfect when smoking, no miss. I cranked it back up later, and it smoked a little bit once again, and went away. NOW< is this a head gasket blown, pulling coolant into the cylinder, and burning it off? OR, is this a turbo oil seal blown burning oil and crap everywhere, because my turbo seal i KNOW is going bad. its using oil when the turbo spins, and lately, every now and then, it will smoke on start up, and smoke whenever i got some boost. I will be doing a comp. check tommorow, to help determine the problem.
thanks and please give me some suggestions
