John Larkin
Sublime Master of Turbology
- May 25, 2001
Hehe!
Ok, did some searching and found that a guy had used an '85 Station Wagon master cylinder with 1.25" bore on a 12" brake conversion. I'm not interested in the conversion, but the master cylinder is worth thinking about. Apparently, the G-body style master cylinder (vacuum system) has a bore of 0.8". Obviously less pedal pressure would be needed with the bigger bore to push an equal amount of fluid since pedal leverage remains equal. So, the theory is when needed, the larger bore would be advantageous to hold boost, right? The part number is Cardone 10-1863; I was quoted $18 + core. Sounds pretty schweet if it'll fit my booster.
