Junkyard Parts Donor List...
Engine Wiring Harness Replacement
The engine harness from an '86 FWD GM w/a 3.8L will fit, has same connectors, have to lengthen some wires, ECM is same also. GM# 1227148
http://www.turbobuick.com/forums/junkyard-dogs/305412-engine-harness.html
Fuel Pressure Regulator- DIY
The junk yard is a good source for these regulators they are on a lot of the 3.8 and 3800 FWD GM cars:
1984 - 1988 CENTURY
1984 - 1987 REGAL
1985 - 1988 ELECTRA
1984 - 1987 RIVIERA
1986 - 1988 LESABRE
1985 - 1987 98
1987 CUTLASS SUPREME
1987 CUTLASS
1986 - 1988 DELTA 88
1984 - 1988 CUTLASS CIERA
1986 - 1987 TORONADO
1987 - 1988 BONNEVILLE
1988 - 1990 ELECTRA
1988 - 1990 RIVIERA
1986 LESABRE
1986 - 1988 SKYLARK
1988 - 1991 LESABRE
1985 - 1987 SOMERSET
1988 - 1990 REATTA
GMC
1991 - 1993 C1500
1991 - 1993 S15 JIMMY
1991 - 1993 C2500
1991 SONOMA
1991 - 1993 K1500
1991 SYCLONE
1991 - 1993 K2500
OLDSMOBILE
1988 - 1990 98
1986 DELTA 88
1985 - 1987 CALAIS
1988 - 1991 DELTA 88
1988 CUTLASS CALAIS
1988 - 1990 TORONADO
PONTIAC
1988 - 1991 BONNEVILLE
1985 - 1987 GRAND AM
1989 FIREBIRD TTA
http://www.turbobuick.com/forums/parts-sale/273585-diy-pressure-regulator-atr.html
Heater Core Replacement
http://www.turbobuick.com/forums/general-turbo-buick-tech/279035-parts-house-heater-core-2.html
http://www.turbobuick.com/forums/parts-wanted/319316-heater-core-86-gn.html
Hoods- Aluminum
Aluminum hoods and trunk lids are on mostly 78-80 vintage G-Body
http://www.turbobuick.com/forums/general-turbo-buick-tech/301360-aluminum-parts-gns.html
Intake Emblem –84/85 cars
The same emblem was also used on N/A 1985 3.8 (not 3800) FWD Buick Park Ave. intake manifold.
http://www.turbobuick.com/forums/hot-air-non-intercooled-tech/311572-intake-emblem.html
MAF Sensor- 86 / 87 GN
GM # 25007866 & GM # 25007861
http://www.turbobuick.com/forums/junkyard-dogs/74824-how-i-d-lt1-maf.html
MAF Sensor-LS1/LT1- requires Translator/ Translator Plus
3.5" LS1 -- GM # 25179711-- AC Delco # 213-353 (May have been replaced by 213-4657)
Used on:
1998 CHEVROLET CAMARO SS V8 LS1 5.7L 350cid GAS FI N Engine VIN = G
Note: 1998 and newer 5.7L?
3.5" LT1 -- GM # -- AC Delco # 213-252 (May have been replaced by 213-353)
Used on:
1996 CHEVROLET CAMARO Z28 V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
Note: Used on 441 cars - GMC Yukon, Pontiac Firebird, Isuzu truck, vans, etc.
3.0" LT1 -- GM # 25180303-- AC Delco # 213-352
Used on:
1994-96 CHEVROLET IMPALA SS V8 LT1 5.7L 350cid GAS FI N Engine VIN = P
Note: Used on 255 cars, Buick Road master, Chevy Beretta, Cadillac Fleetwood
http://www.turbobuick.com/forums/general-turbo-buick-tech/115104-lt1-maf.html
Marker light Assembly
Right side with black bezel: GM # 919874
Left side with black bezel: GM # 919873
http://www.turbobuick.com/forums/general-turbo-buick-tech/307400-question.html
Radiator Conversion- F-Body
OEM replacement radiator for a ’87-’92 Camaro
Modine 951 and/or Ready Rad # 433918
Note: 951 only have 1-1/8" tubes.
Autozone p/n 433918 has 1-1/4" tubes
A/C Delco 20571 (p/n 432397) is 1-3/8" tubes
p/n 433963 is 1-5/16" but trans cooler is on drivers side
p/n 432140 is 1-5/16" tubes and has 2 trans coolers
http://www.turbobuick.com/forums/ge...9967-f-body-radiator-no-oil-cooler-lines.html
http://www.turbobuick.com/forums/general-turbo-buick-tech/295528-f-body-radiator-what-years.html
http://www.turbobuick.com/forums/ho...ech/296160-modine-951-f-body-radiator-ha.html
http://www.turbobuick.com/forums/general-turbo-buick-tech/285700-f-body-raidator.html
http://www.turbobuick.com/forums/ge.../195015-possible-overheating.html#post1374622
Trunk Lids- Aluminum
Aluminum trunk lids and hoods are on mostly 78-80 vintage G-Body
http://www.turbobuick.com/forums/general-turbo-buick-tech/193377-aluminum-hood.html
Wheels- GNX
Buick GNX rim manufacturer: JWL (Japan Light Alloy Wheel)
Manufacturer info: JAWA | Objective
GNX rims were available in 16x8.
Buick GNX came fitted with these rims in 1987.
All GNX rims were not dimpled and were a 2-piece design.
The GNX are marked “OFF-15” for the fronts and “OFF-23” for the rears. Both front and rear also have the marking of “8JJX16”.
Front offset: 15mm
Front backspacing: 3 15/16”
Rear offset: 23mm
Rear backspacing: 3 9/16”
http://www.turbobuick.com/forums/brakes-suspensions-tires-wheels/200426-info-gta-wheels.html
http://www.turbobuick.com/forums/parts-sale/297503-authentic-gnx-wheels-needs-refinished.html
Wheels- GTA / Trans Am
Pontiac GTA rim manufacturer: JWL (Japan Light Alloy Wheel)
GTA rims were available only in 16x8.
The Pontiac GTA’s came fitted with these rims from 87-92.
GTA 86-88 are the non-dimpled 2-piece design.
GTA 89-92 are the dimpled 1-piece design.
The GTA’s are marked “front” and “rear”.
Front offset:
Front backspacing: 4.75”
Rear offset
Rear backspacing: 5.25”
Notes: It has been stated that the dimpled style is more desirable. The reason GM made the dimpled style was because the non dimpled style center hub was weak and was prone to cracking. In addition, 4 fronts are more desirable due to the offset.
If you run 12" brakes in front, rears will actually fit better than fronts, due to the 3/8" increase in track width per side of 12" brakes.
or …
If you plan on having the front wheels narrowed, for drag racing or a big/little look, the "rears" will work better if narrowed than "fronts".
NOTE: Set of Four FRONT GTA WHEELS 16 X 8" from the early Turbo Trans Am don't require spacers!
http://www.turbobuick.com/forums/pa...front-gta-wheels-professionally-restored.html
Gonna add one more for you Mark. Lower rear control arms off a 4th gen Camaro are the same as the G body. Have the exact same holes to mount the sway bar and the bushings need to be changed but everything else is the same.
Charlie, is this an upgrade? Like maybe boxed control arms or are they just a stock replacement U-shaped control arm? Also is this model specific like the 1LE camaro or WS6 TA? Thanks
Not an upgrade but mine were so rusted and I had a set in storage so I compaired them. Exactly the same except for the bushings. this is a stock replacement arm.
Under Hood and Trunk lighting
These are relatively easy modifications that you will get much use out of. If you do not have an under hood light, you can grab one from many other GM vehicles and add it to your car. Another addition, most A/G Bodies were designed to use them on both the left and right sides of the hood, depending on application. It is very easy to add a second light to the unused mounting area. The same goes for the trunk lighting, many cars were available with this, so adding this isn't very hard to add either. Another idea I've used: on some 80's/90's Chevy/GMC, Ford, Dodge Full-Size Trucks/SUV's, you can find the optional extending/retractable under hood light. They are not very common, but are usually found on the upscale versions. These are easily adaptable to add to your car's current under hood or trunk lighting and come in very handy at night. All were used under the hood of trucks, so they are often in rough shape. I added it to the rear trunk area where it was kept clean and dry and served me better. I haven’t come across one in awhile, but they are out there.
View topic - The Junkyard Interchange and Rarities Thread • GBodyForum.com - '78-'88 GM G Body Community
Monte Carlo SS Engine Compartment Lighting
Windshield Antenna
This eliminates the ugly antenna on the fender. On some earlier '78-'81 A/G Body's, GM did use a windshield with the cast-in antenna like their earlier kin. These are a real PITA to remove in the junkyard, but most good glass shops have them in stock. All '78-'88 G-Body's should have the antenna hole predrilled at the center of the windshield channel base/dash mount. If yours doesn't for some strange reason, you should be able to see where it is supposed to be and drill it.
...Another idea I've used: on some 80's/90's Chevy/GMC, Ford, Dodge Full-Size Trucks/SUV's, you can find the optional extending/retractable under hood light. They are not very common, but are usually found on the upscale versions. These are easily adaptable to add to your car's current under hood or trunk lighting and come in very handy at night. ]
Excellent tip. My '92 p/u had it, and I was shocked when I found my '04 came with NO underhood lighting, even though I have a well optioned truck. I just never thought it wouldn't have one like my old truck! I bough it for the new truck, but it would be just as well suited in the Buick.
Can we have a thread on which seats would be a simple bolt in for our GN's? I saw a 94 Roadmaster on Craigslist being parted out. Would the seats fit a GN? I've seen mid 90's Park Avenue seats in a GN and they looked real good.
I can recommend a part not mentioned in this thread. The front valve cover on 85 3.8 front drives has an oil fill hole and front breather access. You can use this valve cover for the passenger side of your TR and have breathers on both banks.
Stupid wiper sprayer part
I am trying to track down a couple of the tiny plastic wiper sprayers for my car. The nipple that the hose attaches to is broken and cannot fix it. Thanks 87PearlRegal
Go to the botom of the main forum page and look at the vendor section. Then you can go to his site and get the info you need. I believe his screen name is Bweavy but I may be wrong.
Front Fender Braces
The front fender braces are missing from the factory. They were installed from the factory on their G-body cousins the ‘78-’88 Olds Cutlass, Pontiac Grand Prix, and Chevy Monte Carlo.
Turbo Regal Body Bracing
Damn, this list is going on 26 pages!!! Alot of work organizing- but it's been a pleasure helping others out!!
