Kinda funny, took the car out for a blast yesterday, and tried tuning a little. Started off with 16# of boost and ran a WOT and had to let off the throttle as my boost creeped up to 18# in third
and looked at the 02s which read 760 or so with spark retard on the scanmaster of about 3.2 or something like that. Turned the rod down one full turn, and tried it again with the boost going up to about 14-15# and creeping once again to almost 17# in third. Let off the gas as the knock gauge started on the first green light then going up a to the third green light. 02s read 769 and spark retard showed 0.9. So i kept it there. This morning on the way to work really confusing
i was cruising at about 35mph and punched it to pass the slow pokes and i felt the gear drop down to second real quick as the car pulled, but then i seen the knock gauge quickly go to the second green light, so i let off real quick and checked the scanmaster. 02 were 789 and retard was 2.4
. What is going on? fuel pressure set at about 46-47# line off when i checked when i got to work everything on the car is pretty new pump,hot wire, regulator,fuel filter, ect.. and am running 91 octane right now just confused how i took it for a blast yesterday and left it at 15# with 0.9 retard and today it did what it did. Any good advice or things to check for i appreciate it. Oh sorry for the long thread but i figured you guys would need details to know what to look for
thanks
jojo
thanks
jojo
