I need some help here. When I start the car, the beep and light switch's are set on the "on" position. The light comes on together with the beep. But, when I run the car, at the 2nd to 3rd shift, I get one flash from the light but no beep. I thought that both should come on. I used two different units with the same result. Am I knocking or is it false knocks?
Thankx
Thankx
