Ant mast
Anyone know how to disable the Antenna mast besides pulling the fuse? The motor continues to run when the car is turned off. It must think the mast is still up. Where is the connector for the motor? In the fender? Any help is appreciated!
The connector is on the passenger side fender - I forget which color it is - my car is in storage.
You will know which one it is when the antenna motor stops running:D
It has 3 wires green, gray and white.
X2
Just Pull The Plug.. The Cable Inside The Mast Is Broken,along As The Antenna Itself Is Ok, You Can Purchase A Repair Kit... Kirban's Sells Them For Approx 25.00,it's A Job, But An Every Day Guy Can Do It..
You have to dig for it
dig down beside the heaterbox and find the wire with green white and gray. and unplug that one.
