I installed a anti sway bar and noticed the bar was sliding to one side after driving a short distance. The bar moved a couple inches to the drivers side. I did not run the car hard just some slow driving.
Any idea what this indicates? I did notice the car is about 3/4 inch higher on the pasenger side that I can correct with the coilovers.
Sure makes a huge difference in manners on the street compared to stock style sway bar.
The instructions made no mention of type of lube for the poly bushings. Should I use a particular lube ?
