mine look exactly same,except not chrome.mine dont have the bar welded to the turbo perch.i would like to know what they are also.all i know is they were installed on my car back in prior to 95.
i like them,i just bought some gaskets for the crossover pipe.i had to grind down the outside to make work with the vband clamp.mine measured 2" id.
is that the same on yours?
i was told stock were bigger than 2".
They are the speed daddy headers from eBay. I have a set. They are nice. They need to be massaged in place they don't fit out of the box but I like mine. I just recently changed my dp so I have a set in the garage.
It's like 2 1/8" but it's a step down the actual pipe is 2 1/4". Just found them on eBay gonna use them because it's all I have hopefully they hold up if not I'll buy a stock setup
the crossover pipe vband wasnt pinching enough,so i ordered two gaskets from rjc,the id on those are 2.5.so i grinded down the outside to the same at the mating dimensions on the crossover,and it worked perfect.it made up for the little bit of looseness.
the slip part didnt leak,it was the vband wasnt quite flat against each other.
