any one willing to help a newbie out!!!
Sounds like your almost there. How about the PCV valve? Either bad or possibly the wrong one.
we put vacuum on all hoses and they held pressure.
so none of them leak the line to the map sensor was leaking but we fixed that also.
i just installed a new valve
once the pump is in ill update to what's going on.
thnx every1
time for a fuel pump and hot wire:biggrin: your fuel psi should rise one to one with boost so 43 static psi plus 11 at wot you should have 54 psi
it does rise 1 for 1
but right wen it gets to the top it shoots down back to the start.. and it starts leaning out..good thing there was no knock..
fp should stay up with boost it should not come down unitill you let of and boost comes down
