Any parts on an 86 z28 I can put on my T?
grey1
SMOKE 'EM
Picked one up for free this morning. Motor has tpi. Old owner said it has a hole in the block. I did notice a freeze plug pushed out. 74,655 orig miles. Can I add or swap anything off of this car? Thanks
The front sway bar will fit. If it has the 1LE you can use the rotors and calipers w/ B-body spindles. Those are the only two I know about.
Later,
Steve.
if it has rear drum brakes, maybe they are aluminum and the rear drums will fit our cars.
BW
what you doin with the TPI motor?
Is it a 305 or 350? Either way at least keep the heads, What kind of shape is the car in? is it a typical Minnesota car? ( I live in Blaine) If you're parting it, is the hood still in good shape? a friends been looking for a Z hood. Call me anytime after 11 AM 612-708-8015 Brad
It's a 305. The car has no rust. Driver's front fender has a ding. We got it running last night. Block has a hailine crack behind ex. manifold d.s. Interior is tan and car is blue. Glass is all good. I'm in Elk River. Dave. Hood looks good.
