I have redone my brakes with new calipers, cylinders, stainless lines, new powermaster complete and I have tried to power bleed and manually bleed the system and can't get it to work. When it's power bled it will not suck solid fluid except from the front driver wheel. I read that if your brakes improve from bleeding that caliper then your proportioning valve is ingesting air. Would it be true in my situation? Mine is rusted but there are no leaks on system at all.
