S
Stephen Soulsby
Guest
I'm in the process of installing my motor and transmission in my '84 T-Type. I replaced the tired stock turbo with a liquid cooled TA-33. My question is what is the best way to hook up the cooling lines. I have two 5/8" heater hose fittings on the turbo. I would like to avoid using the heater inlet line because water will only flow when the heater control valve is open. It's been two months since I first pulled and disassembled the motor. There is a fitting coming out of the bottom of the compressor housing on the turbo. I have forgotten how it hooks up. I believe it was a water line. Any help or photos greatly appreciated.
