I have had my car lowered about two years now. Two inch drop spindles up front and 1 1/2 inch lowered springs in the back. Rear rims are eight inches wide with a four inch backspace with a 275/60/15 tire on them. Recently have had problem with the left rear rubbing. Rubbed bad enough that it bent the wheel well trim down. Used a bat to roll back up but it still rubs. I can tell that the tire on the driver side is definately closer to the wheelwell trim than the passenger side. Also can tell that the driver side sits slightly higher in the back. I have heard about other cars bodies not sitting on the frame evenly like mine, but I couldnt see the body shifting causing my problem recently. The only things I can think of is go on a diet, raise the car back up, or the left rear spring lost strength. What do you guys think????????
